andrewddrennon
Thread starter- Joined
- Jan 17, 2011
- 73
So i have a no spark situation on 1996 ``ED'' 40 horse johnson. I performed the charge coil output tests after eliminating the kill wire. It showed I had no output. So i ohms checked it and it showed ok that way. Then i ohms checked the power coil side of the stator and its not ok. So this led me to believe i had a bad stator for sure. Bought a new stator and put it on, still no spark. So i ohms checked the new stator, both sides test good. I checked the output and it still shows nothing. And Yes im using two known good dva/pva meters. The manual says to test the outputs of the stator with the amphenol connector unplugged/ not in line with power pack, did it that way still shows nothing. Did short to ground test as well, its not shorted. I didnt see any bad magnets under flywheel. Any ideas would be greatly appreciated.
