JoLin
Thread starter- Joined
- Aug 18, 2007
- 5,146
Got some great baseline stuff this morning. Went out early while the bay was very calm, with no wind to speak of. Here we go:
The boat is a 21', constant deadrise (20 deg) v-hull. No "flattening" at the rear. She's also stern-heavy. Main motor is on a 30" setback bracket, and there's a 4-stroke kicker and bracket. Both batteries are also situated near the stern. Tabs will probably go on soon, but I want to concentrate on the prop first.
Current prop is 15x17, 3-blade aluminum in good condition. It's what I'd consider an "oem type" prop- no discernable cupping or ventilation.
Johnson spec calls for WOT range of 4500-5500 rpm
With normal load and motor trimmed for best speed, I'm pulling 5200-5300 rpm at WOT, at a GPS speed of 37.5 mph. I'm pretty close to optimum, but I think there's a little room for tweaking.
Does it all sound right? Can someone recommend a specific prop brand/model?
Thanks, folks!
- I want stay with aluminum for now
- I want to maximize lift, hole shot and mid-range performance. Under normal (choppy) bay conditions, the boat and passengers are most happy at around 4000 rpm/26 mph
- I'm thinking maybe a 4-blade prop with a 1" reduction in both diameter and pitch - 14-ish x 16
Thanks, folks!
