cgrooves
- Joined
- Aug 1, 2007
- 57
I asked this question in another thread, but rather than thread-jack, I figured I should start my own.
"If the anti-siphon valve is a 1-way valve, I assume it will allow fuel to flow in the direction 'from the tank to the fuel pump'. In the event of a fuel line failure between the anti-siphon valve (at the tank outlet, as I understand it) and the fuel pump, how would it keep fuel from emptying into the bilge since it is installed to allow fuel go in that direction?
Am I just wrong in my description that it is a 1-way valve? All anti-siphon valves that I am familiar with (i.e. plumbing related) are 1-way valves, but it sounds like the anti-siphon valve at the fuel tank will allow fuel to flow if there is a strong vacuum created (i.e. fuel pump) but not allow fuel to flow if there is just the pull of gravity present (i.e. fuel line failure causing an open system)."
Can someone explain this for me? I need educating
