Extending transom height
BuzzStPoint
I have a project boat.
14' 1972 Skiflite
I found the transom to be rotten.
Here's some pics
http://gallery.computervitals.com/main.php?cmd=album&var1=Glastron+Boat/
I've already replaced the transom, fiber glassed the back cap and in the stages or smoothing out the sides.
I just picked up a 55 horse motor for my boat.
But found it to be a long shaft.
I have a 16" transom.
Without removing everything I've done. Is it possible to cut the back lip of the boat, and Add on to the transom and fiberglass in?
problem I can think of it it being weak where the two pieces of the transom meet. What about drilling straight down into the transom every 6-4 inches and putting hardwood dowels and gluing the upper portion of the transom to the lower portion. Then re-fiber glassing and making the transom level with the sides?
86RajunCajun
Re: Extending transom height
Id have a metal bracket made of plate metal and bolt it onto your transom. You prolly only need abour 4 more inches of height. I did the same thing with a 12 ft V hull i have and used a pontoon boat 9.9 long shaft.
Good luck
RC
Ayuh,... It would make more Sense to find the Right motor.....
osborn159
i think id listen to bond-o on this one
BuzzStPoint
I'd love to do that. But it's a budget build here.
Boat, 20 horse and trailer : $125 Last year.
Supplies so far: $100
55 horse: $250
Raising the transom wouldn't be that hard. It's just reinforcement issue. Making sure it wouldn't break or bend.
jonesg
Raising the transom for 10 hp is nothing like 50 hp.
I'd install a new transom and a jackplate for the outboard.
Ayuh,... Raising a 50hp motor Changes balance,+ center of gravity, causing tippyness...
Or Worse...
Just because you found a Cheap motor, don't make it the Right motor for your application...
