Mostly Harmless
- Joined
- Mar 30, 2009
- 49
So I am just about up to the point in my project of installing the actual floor boards. I have rebuilt the stringers, foamed them in, and have two out of three floor boards cut and mocked into place. The third floor board is very tricky because it sits in the front of the hull and follows the V of the hull which is unlike the other two boards that rest on a platform where the V meets the sides....anyway, for this project I have been using the best materials I can find which includes marine grade plywood that is 13 ply thick and is the nicest wood I have seen, while using the old front floor board to help mark out the new front board I notice a very curious marking on the under side of the wood:
Apparently back in 1974 they used exterior grade plywood instead of marine grade plywood. I find this rather funny because I originally thought it was marine grade and tried to follow what the manufacture did. So now I will have a slightly heavier boat (I believe the marine grade is heavier then the exterior grade, I just don't know how much). But now it should be better then the original.
