Re: Exterior hull delamination, easy fix?
Sorry for the delay m8..
I was sure it was a bulkhead hardpoint..but from your pics I can see .. well..no bulkhead
( though it looks like from the wood cut and in your pic seems like it was repaired on the inside allready.. ) the strips of glass do not look right for manufacturing .
The only thing I see in your pics might be a prob with the lower left .. where it goes through your strake..It looks white..
Here is what I would do.. cut the bulk of the delam off the outside as possible ( saves grinding ) .. then grind ALL the white dead glass in one spot till it hits good glass.. ( do not feather grind at this point ). If it goes through..then you could get away with prep and glass from the inside and make your new hull in that area.
Not to get your hopes up..but there is no bulkhead..and you have access now..I dont see a reason that you cant repair this safely.. You just have to grind all the dead glass out..and bevel and re-glass..
Grind your outside.. get pics..post and show. When you grind all the dead glass out your close ..
YD.
PS. Again.. sorry for delay.
