External to Internal Voltage Regulation
Re: External to Internal Voltage Regulation
Sure,.. If you want...
gjcombs
Okay. That's the short answer. ;)
Are there any gotchas to matching charging ability or wiring? The one depicted in the link only has a ground connection and a wire that goes to the battery.
Ayuh,... Not really,... An alternator will only produce whatever power that is required...
Just by-pass the regulator...
Btw,... That's a ground,+ the wire that goes to the battery lug on the Starter...
