Extra Drain Plug from Winterizing on 4.3L
hhornig
We had a cold spell and I am new to the I/O world and needed to get my boat winterized quickly, so I had the local boat shop do it. They gave me a bag with 5 plastic drain plugs and one pipe fitting plug which looks as if it is a standard 1/2" pipe thread. I have found where all the plastic drain plugs go, but can't find where the metal pipe plug goes. Does anyone have an idea?
Bt Doctur
Re: Extra Drain Plug from Winterizing on 4.3L
does it have a square head? May be the hull drain plug
Shamfarlango
Hull plug would be my guess. In true iBoat fashion, a picture would get you a more definite answer.
hhornig
It is not the hull drain plug. It is a standard mpt pipe plugh with a square end.
boat127
intake plug it goes infront of the intake manifold
BRG25
My 4.3 has 5 drain plugs (blue). On each size of engine, 1 block, 1 exhaust manifold. 1 on the the hose connected to the water circulating pump. The Garboard bilge drain also takes a 1/2 pipe plug.
As a side note, many guys have replaced the blue drain plugs by removing the whole fitting(s) and replacing with a pipe plug.
scoflaw
Ensign
Your local boat shop might have a little insight on the answer to your question
littlebookworm
You didn't say which engine or year you have. My suggestion is to check the daiagram for the cooling circuit for your engine. If you don't have a repair manual, you can download a free one from 4share.com. Then check the diagrams. They will tell you where everything goes. Hy
hhornig
It is a 1999 4.3L
fossill
Why didn't he put the drain plugs back in? Merc advises against storing boat with the plugs removed.
littlebookworm
Sorry. The website for manuals is 4shared.com. Try it. Hy
achris
More fish than mountain goat
Quite correct... see below, an extract from service manual #25, page 1B-30...
attachment.php
Chris.....
