WinnerCougar74
Thread starter- Joined
- May 12, 2020
- 315
I just wanted to share some recent issues from a fishing trip. 2 times the engine died and would not start out on the water. Fortunately I have a 9.9 kicker motor and it got us home. The kicker cost me about $800 total so that was cheap insurance. Well worth it for peace of mind with a 47 year old motor.
First time: some how the #3 plug electrode got smashed. They were "gapped" NGK 4322 (BR8HS). Checked compression and inspected #3 cylinder and it all looked good. Best guess is the spark plug electrode heated up and caused detonation which fortunately only smashed the plug electrode. Installed NGK BUHX "gapless" plugs. The previous owner had I had BUHW. The BUHW foul easily. The BUHW have a wider gap and do not have an anti-foul design. The BUHX have anti-foul design and smaller gap and are the factory recommended plug so I'm going to try sticking with these. So far I have been able to do a lot of trolling without them fouling. So I'm sticking with NGK BUHX for now.
Second time: tear in fuel pump diaphragm caused fuel to dump into the exhaust and out the bottom carb. Started out thinking is was the float bowl seat but I was wrong. It was the fuel pump diaphragm. Replaced it and it ran good. Some on this sight said a backfire or cough could cause this. Coughing is common on my motor so the fuel pump diaphragm is likely to be a week point for this engine. Fortunately I bought many diaphragms so I put a new one on and was back on the water.
Third time: points were corroded and engine would not run well enough to get up back to the dock. After much time trouble shooting I found the very corroded points. I had just replaced them in April. Amazed they would have failed so soon. I put new ones in and was back on the water. I have heard if you are using and non-CDI ignition you do not need a condenser but I'm thinking of trying a condenser to make the points last longer.
After I made all of these repairs the motor ran good for 3 days.
Lessons learned. Have extra parts like, fuel pump diaphragms, primer bulb, fuel line and fuel line wire ties, spark plugs, points, seals and gaskets with you at all times because it seems like you will need them. Keep almost any parts you replace in a box in the truck. They just might get you back on the water during your vacation. The extra parts might even get you back on the water. This one is a no brainer but also keep tools on the boat including a good flat head screw driver, plyers a set of SAE wrenches and sockets and a spark plug socket.
Please post your general suggestions for keeping these Chrysler motors going either on the water or at the dock.
