EZ Bottom Painting Again
freelancer
Been using an ablative water based bottom paint for three seasons now. The 1st season I hired a hand at the boat yard to do the work and after seeing how easy this paint was to use, I've done it myself for the last two seasons. I keep my boat in fresh/brackish water all summer except for about two weeks when I head down to the Chesapeake Bay for a little cruising. A half a gallon did the job today, my LOA is about 26.1. The hose at the boat yard was all the clean up that I needed. One less thing on the list for next weekend :D
a1akeywest
Banned
Re: EZ Bottom Painting Again
is it just me or do those blocks look a little precarious?
Sounds like you only did one coat. Is that enough?
freelancer
Chris1956, your right one coat of black? but it seems to be holding up for the season. There was a grey primer coat that I could see coming through when I started using the paint a few seasons ago. I?m not sure what was originally used for the bottom paint but I do know it was ablative.
In the fall when I get a power wash a good amount of black paint comes off but not all of it, I can't see any more grey primer, just the current seasons black paint. If I go with two coats, do you think I can skip a season? In general it?s both a cosmetic and a maintenance thing; I don't get any type of growth that hasn?t come off with the end of season power wash.
I do think you can go two seasons with two coats of paint. Also, the second coat will get any missed spots that you might overlook.
I almost went with the water-base AF this year. However, I thought it easier to toss out the chip brush, foam roller and paint tray liner vs washing them out. In addition, I was afraid that cold weather or rain would ruin the water-base paint, if it didn't dry quick enough. I stuck with the oil base AF paint....
