f--inscreenname, check it out
Re: f--inscreenname, check it out
Ya,<br />Old Boats $uck.........<br />Don't They.................. :D
Dhadley
Look closely. Its obviously a "bubble back" crossflow. The ignition they have on the motor was last used in 1979. The first "bubble back" V6 was made in 1978 and was a 235.<br /><br />The hood is for a Johnson. The motor is not a Johnson.<br /><br />The hood says VRO. There is no oil injection pump of any kind on the motor. It has fuel pumps. Clearly pictured.<br /><br />He claims it to be a 1991 235. OMC didnt make a 235 in 1991.<br /><br />Technically the motor is not even an outboard. Its a Sea Drive.<br /><br />Sea Drives were equipped with 35 amp alternators. This one has a 10 amp. Which leads back to the early 235 made in 78 and 79.<br /><br />He claims it was rebuilt. It seems odd that someone went to all the trouble to rebuild the motor and painted the block red. Unless the block wasnt painted and the original paint flaked off and the red primer is showing thru. Very common for the OMC motors in the late 70's. <br /><br />He's using an old powerhead on a Sea Drive mid section with a Johnson hood. I'm not saying it wont work because it will. Im saying he has misrepresented the powerplant.<br /><br />So what else is he misrepresenting? If he fudges the truth about the motor, which can be verifed visually, hes most likely fudging the truth about the hulls condition which cant be verified visually. Not the cosmetic mess but the condition of the stringers and transom.
f_inscreenname
I must say Allmand did a great job of closing that stuff in. After 32 years mine are still solid as a rock (transom, stringers). They are running the bids up to early. The way I do it is wait till the last 30 sec’s then make your finial and only bid. It is to easy in the heat of the moment to bid past what you should have stopped at when you get into a bidding war with someone. You only show your cards at the end of the hand and that is the way you should play the game of E-bay.
mercrewser
Its not taking us to the page. Look under the manufacturer of "NOVA" should take you to the only listing.
f_inscreenname
I think that is a Wellcraft Nova SS. Never know for sure. E-mail address is no good. Thanks for keeping me in mind. Mark
