Re: f200txr Is not idling or running well, getting a code 29
Reading when I disconnected the ISC:
Monitor Item Result Unit
Engine speed 0 r/min
Intake pressure 100.68 kPa
Intake pressure 29.8 inHg
Atmospheric pressure 1006.8 hPa
Atmospheric pressure 29.8 inHg
With ISC connected:
Intake pressure 117.44 kPa
Intake pressure 34.76 inHg
Atmospheric pressure 1066.7 hPa
Atmospheric pressure 31.6 inHg
Reading all done with in mins of each other so the Atmospheric pressure should be the same on both readings. Also the Intake pressure and At Pressure should be the same on all normal readings.
Contacted Yamaha Directly. Wow what great people over there. They have a 800 number and I was able to talk tech talk with a live Master Tech. Made it easy to dignose. He looked up in his Yamaha Technical Service Guide some trouble shooting question. And was able to help me dignose the problem.
Also was able to give me the variables to check the ISC. Turns out a bad ISC/stuck open ISC valve can give out a code 29 error. So that was the problem. ISC valve was unplugged and I got no more code 29. Also I told the tech that the motor would not idle, back fired, and stalled out. He said if all other machanical problem have been check then it sounded like a ISC problem with the code also being 29. He found that in the Yamaha Technical Service Guide.
I was able to purchase the YTSG on ebay today for only $30.00 So I will have it in the future.
As Rodbolt said, do a voltage check on the black and orange wire of the IAPS. Yamaha tech told me that the black and orange wire also is on the TPS and they should be all 5 volts. using a peak voltage meter.
And that is what I got on both sensors 5 volts when the ISC was not connected. Other then that it was off by 1 to 2 volts.
I ordered the ISC today should be here in a week. Will keep you guys posted. Sure would like to go diving with my daughter. I will post picture of my boat for you guys can check it out.
Thx again to Rodbolt post and Justintime on the phone calls..
With ISC connected:
