gene8084
Thread starter- Joined
- Sep 29, 2007
- 187
Re: Fails to choke at start
I appreciate your patience. I have what I thought was a pretty good shop manual. It's great at describing overhaul (disassembly/assembly) of systems, but does describe how and why things work the way they do. I've also downloaded a couple and bought a CD based version of another on eBay. So, I'm going to paw through all three and see if I can find anything remotely like you provided.
If all that fails... I'll keep looking for a mechanic willing to work on this old tug. I certainly don't mean to impose.
You really need a service manual sir. That said -- I'll give you a brief overview. Setting the choke means moving the throttle forward to allow the choke plate to close. Whether or not it actually does is not important at this point. The point here is that you can't adjust the choke if the choke is not "set" (allowed to close). Now if the choke plate is not fully closed, adjust the disc. Then start the engine. When the engine starts, it develops manifold vacuum which is fed to a choke pull off. Vacuum acting on the choke pull off diaghram sucks the plunger inward, pulling on a linkage that pulls the choke plate open a little to allow the engine to idle properly. If the diaphram in the choke pull off is ruptured, you have a vacuum leak and the pull-off cannot operate so the choke remains fully closed hence the rough idle or no idle. On some carbs the choke pull-off is built into the carb itself and operates via a vacuum piston. Then the choke heater (the electric heating element behind the disc) begins to open the choke fully. If that's not working the choke will not open either. There you have it. Perhaps now you can understand the value of a service manual because this description would be accompanied by pictures. You might make a trip to the library as they often have service manuals you can check out.
