FAULTY SENSOR?? 97 Johnson 175 Ocean Runner
HS91_Mike
1997 Johnson 175, Ocean Runner ? Faulty Sensor? I had some extensive work done on this engine including having the carbs re-built, the head o-rings replaced, the VRO pump removed and a new fuel pump and lines installed. Basically repaired the fuel system from tank to carbs. The engine has run great with the exception of the ?Check Engine? alarm going off. The mechanic said don?t worry about it, it is just a bad sensor. The Alarm usually went off at 4200 RPMs and whenever the hull hit a bump in the water like a wake and jarred the boat a bit.
The other gauges (temperature), Hot, Water pressure and so forth appear to be within range. A recommendation was to disconnect the sensor so that it would not trip the alarm or trip the power-pak and see if that fixed the problem (problem assumed to be faulty sensor). If so, then we replace the faulty sensor. My concern is running the boat without this warning sensor. Don?t want to risk burning up the motor. Any advise is much appreciated.
Mike
jonesg
Re: FAULTY SENSOR?? 97 Johnson 175 Ocean Runner
alarms when boat hits a bump,?
how are your battery connections?
no wing nuts eh?
If battery is good and solid and all connections are shiny and tight...
then test the sensors.
But it sounds more like an intermittent ground (chafed wires etc) .
Can you induce the alarm whilst its running on a hose?
Do you know from the sound which alarm is sounding?
or is it just a momentary beep?
if so then I'd say again, either poor 12v supply connections at battery/starter or chafed/melted wiring somewhere.
Also look behind the ignition key lock, any excess wiring dangling banging around under there?
HS91_Mike
Not following you. Do you mean running off an auxilary tank?[/B][/COLOR]
Do you know from the sound which alarm is sounding? Yep. It is about 5-10secs long and then the "check engine" light stays on for a few minutes. Then 3-5 minutes later Bop on the hull and BEEEEEEEEEEEEEEEEEEEEEEEEEEEP!! And we just keep going.
Not reallyu
