thephoneman
Thread starter- Joined
- Apr 24, 2009
- 75
I was having this issue last fall when I go the boat and motor. So far I have replaced coils, points, and condenser, wires and plugs, as well as lines from tank connector to motor. Blew carb out with air. Good pressure from tank.
Here is what happens: turn tiller to left until it stops (between start and fast). Some pulls the tiller handle pulls back towards shift and slow. Once I get the motor running it will stall if the rpm/throttle gets too low (also if you turn tiller towards shift). Have inspected both mix needles and the low has a little wear below the point but still has a good point to it.
I'm basically a weekend warrior, and have searched the forums for advice but have had no luck. Any suggestions on what to try next? I can post pictures if needed.
Thank you!
Thank you!
