Lord Tywin
Thread starter- Joined
- May 16, 2017
- 80
89 Johnson 70 3 cylinder has been running fine, then last night at a decent cruise it dropped power. Felt like all cylinders werent firing. I throttled back and at a fast idle it was ok to limp back. I pulled the plugs, saw visible oil on a couple and swapped them out with a couple I had from earlier (used but ok). Boat ran fine back home no problem. Today I bought 3 new plugs and put them in. Boat wouldnt start, so I pulled them and made sure they were in good and the wires were seated well. Then it started fine and I took off to meet family. A couple miles in and the same problem surfaced out of nowhere. I turned around and limped back home not wanting to cut it off (in case it wouldnt restart). Back home I pulled the wires off and re-seated them. It cranked and went back to a good throttle.
I'm thinking it's the plug wires and that I can use ones like these "Sierra International 18-5231-1 Premium MagForce 9" Marine Spark Plug Wire Lead" but maybe not the 9" length as these seemed shorter.
Any other ideas of things that could be causing this? I dont have a manual so I dont know for sure these are the right ones but it looks like they are.
Any input is appreciated!
