Gradywhite3535
Thread starter- Joined
- Dec 29, 2012
- 480
First I have 2 spot lights in the boat. One on the front of the center console aluminum top and one on the other side.they are hooked up with the positive wire running to the fuse panel and the ground connected to the bolt that the light is mounted with. The aluminum frame of the center console has a aluinum mounting plate in the inside of the center console that has a ground wire running to the fuse panel. The rear light was working last yeAr.the front one isn't working but the rear one does. If I run a ground wire directly to the front one it works. I don't understand why it's not working. Any ideas? I have a battery switch that I wanted to be able to switch from house bat to starting bat and I must have wired it wrong. I have the fuse panel,engine, and both battery's running to the switch. How should I wire these to the switch?
