BlueGhost93
Thread starter- Joined
- Oct 15, 2013
- 114
Ok so I have a 1972 evinrude 18 hp two stroke. Just replaced the lower seals and water pump. Shift rod and water tubes and drive shaft all look very nice. Very very minor corrosion. I'd say not any but there was a tiny bit of powdery white stuff I scraped out and now looks nice and new inside.
Anyway. Before I did the seals and still now after, when I put it in gear with the motor off, the prop does lock in place when you try spinning it by hand but there is a good inch or so of slop. Is that normal? Or should I not be able to move the prop at all when in drive or reverse?
Also, what's the fuel mix ratio?
And when I tilt the motor up it seems very very stiff and its hard to lift the motor up. Is there a zerk fitting to grease or anything I csn do in order to make tilting it up smoother? Yes its unlatched
Also looking for these parts if anyone has USED or new ones before I pay premium prices for new stuff.
Lid lock pin that the arm grabs to hold the lid on
New rubber style throttle grip (rubber square pattern)
Choke arm
Fuel mix nob
Choke arm
Fuel mix nob
