Fiberglass body filler as Peanut butter!???
jigngrub
Re: Fiberglass body filler as Peanut butter!???
You'd have to know what it's made out of first, if it's a phenolic resin/epoxy product your polyester resin layups won't bond to it.
Lwarden
They say its a polyester base? Im going to call them in the morning to verify!
Lwarden
I was asking about using it in place of PB.
jbcurt00
I asked WHY you want to buy it instead of making it. I understood you wanted to use it instead of PB: Time, mixing? Why?
Maybe you already own a great big can of it?
zool
Its $156.00/gal.......
Lwarden
LOL! Sorry! No reason other than its already premixed and I was thinking it might be cheaper? easier to work with?
jbcurt00
You will rarely mix EXACTLY how much resin you need. So when you need to make just a little more to finish, mix enough to have some left over to make PB. Once you get the glassing done, mix in cabosil, micro ballons, &/or cut up pieces of CSM........
Or when you've mixed more then you needed, do the same........
zool
You're right, my bad...Still, poly resin and Cabosil are cheap.....And I bet that is more of a fairing compund, than PB.....So it would be baloons and resin..
I would prefer to mix to a consistancy i chose....
matt167
Evercoat " Kitty Hair " is about as close to 'PB' as you are going to get with using automotive filler products. It is 30-35% talc according to the MSDS so it is not ideal...http://www.evercoat.com/imgs/msds/100857 Kitty Hair 08-24-2011.pdf
You could buy some empty gallon paint cans and pre mix some PB with Cabosil and resin. Could even use wood flour if you wanted cheap, tho the Cabosil is the more common/ preferred thickener for 'glass boats.. Just mix it a bit thick and do not activate it until you need it.
zool
Ive had good results with Evercoat products...I use them on auto restos...
Woodonglass
to wash it down with Acetone before laying new glass.
