Fiberglass gas tank leak
tin
Re: Fiberglass gas tank leak
OK one more question if you please....The resin tank had no ground other than the sending unit ....Now I'm going Aluminum do I need to ground the tank to the hull as it sits on plywood under the seats the tank would not be grounded.....Thanks Tin
Ayuh,... It needs to be Bonded to the motor block, 'n the fill neck...
