Fiberglass jon boat indent
ethanwerl
Picked up this hull for a back water skiff project, So far i’m sanding and filling areas needed but i have a slight issue with the bow. This is a 3 bench seat type of job boat and the previous owners ripped out the very front seat for open deck which i liked so i could add a floor but now the under side of the bow is slight indented where there would be a good bit of cavitation coming from area i assume. How would one suggest i reverse this and make it back to normal shape considering it’s a thin area it is decently easy to push from inside of boat. Any tips appreciated!IMG_9101.jpeg
cyclops222
You are being to PICKY. Just looking for needless DIY work. It will NOT cause cavitation at the prop. If water leaks in that area ? Fix it.
Set the motor at the correct height and enjoy the boat. (y)
ethanwerl
Well it’s the first project and i want it to be decent because it’s my money lol you gotta understand, i’ll figure a way out if it need be but i’ve been considering the same just leave it be and have fun.
well yes this is obvious lol i’m asking if there is a way to be fixed or leave it be and continue with the rest.
Ayuh,...... Welcome Aboard,....... Put a brace 'tween yer casting deck, down to the keel,....
