torpedoseal
Thread starter- Joined
- Mar 4, 2005
- 10
I have just purchased an aftermarket wakeboard tower for my '95 Mirage 19 ft. I have been told to reinforce the hull at the four attachment points of the tower. The company I bought the tower from recomends the hull thickness to be at least 3/8 of an inch not including the gelcoat. I was surprised to drill in to my hull and discover the thickness to be only 1/4 inch. Is that standard? I expected it to be twice as thick. <br />Now I have to reinforce the hull but I wanted to know what you guys thought about the fiberglass cloth vs. mat. I know little about fiberglass but I have heard that the strength is in the glass not the resin. If I use the mat I will only have to use one layer to achieve the proper thickness, with the cloth I'll nedd probably 3-4. I have also heard that a piece of plywood can be used under the fiberglass layer for addded strength. I guess I don't really now enough to make an informed decision. What should I do? Any advice would be a big help.
