paulrfrancisco
- Joined
- Oct 25, 2004
- 341
This spring I tackled the task of polishing my severely oxidized marroon colored boat that was pink due to the oxidation. After researching this site for recomendations, I came across the postings from MARK24. In his postings, he, or others participating in that thread, recommended to use 400 and/or 600 grit sandpaper and dry sand it, then polish it out.... Well I did this and am happy to report that I had overwhelming success. I wish I had "before" pictures for you to see... FirstI dry sanded it with 400 then 600 grit, then with a 7 inch polisher, used 3M Super Duty Marine compound. With this alone the result were amazing, but I went further and applied a Color restorer using an orbital 10 inch buffer and then followed that with a Meguires Fiberglass polish with teflon and applied this again with the 7 inch polisher... In the end I had I mirror like refplection where before there was no reflrction whatsoever...<br /><br />Thank you for your recommendations. I thought it was kind of drastic, but simply applying the compound alone without the sanding first, had virtually no effect...<br /><br />Paul
