luckyinkentucky
- Joined
- Jul 29, 2007
- 462
This is a multi-part question, so please bear with me.
I will be fixing the bow eye today after removing all of the 'flakey' area on the interior of the hull last night, and removing all of the old wood. I've got the surface down to bare glass with a clean surface.
Would I be better off using something like Marinetex to fill the existing holes, or will fiberglass/ resin serve the same purpose? I want something to fill the holes that will not chip or crack under the stress.
How thick of an area can I lay safely without having to worry about any ill effects such as too much heat, not setting up, etc ... Would I be better off in laying one layer, waiting 45 minutes, sanding, then laying another? Or, is it best to lay all layers at once and let it cool as a mass?
Does a fan blowing on the area help it to cure faster, and keep it cool?
Thanks for the patience!
