Scott Chinsota
- Joined
- Apr 18, 2011
- 216
Re: more pics...
Re: more pics...
follow the instructions in
this. when the bearing carrier seals have been replaced and it looks more like
this, you're ready to fabricate two guide pins for re-install. book says threaded rod. i couldn't locate any in the size i needed so i used 2 1/2 inch bolts. cut the heads off and slot the ends so they can be installed with a flathead screwdriver
align the carrier and slide her in. might have to tap it in the last inch. i used a dowel rod and a mallet. thread two bolts in snug the back off one full turn, remove guide pins with scredriver and needle nose and thread in the other two. tighten slow and even to specified torque.
Re: more pics...
