Fiberglass resin to fill large chips?
ryanr623
Is it good enough to patch large 1"-2" chips (below waterline) in the gelcoat that are down to the fiberglass? Fiberglass strings are frayed as well. Its polyester resin with no talc, so it's 100% waterproof, or so it says. i wont be painting it till the end of the season.
I just want to stop whatever water is leaking into my hull through the fiberglass. (if it even is)
Woodonglass
Re: Fiberglass resin to fill large chips?
Pics would really help, but based on what you say is true, I'd for sure cut some small pieces of CSM, Grind em out a bit with a dremel tool, wipe it all down with Acetone,and patch em with mat and resin. Resin without some glass is pretty much WORTHLESS.
ryanr623
Thanks for the reply, what is CSM? Theres still fiberglass in the chips, but i have heard that fiberglass that isnt covered with gel coat can seep/leak water into the boat.... so id like to fix without re gel-coating it.
Just want to "seal the fiberglass for now" i guess.
Woodonglass
CSM is Chopped Strand Mat. What kind of resin are you planning on using? Do you plan on Re-Gelcoating in the future or Painting?
ryanr623
It's called bondo Fiberglass resin, it has a pic of a boat on it and says its waterproof.. I believe its polyester based liquid. I have it left over from another boat project. It was a kit and i still have some mat left, but was just gonna use resin because i plan on re-gelcoating the entire bottom at the end of the season. I guess i'm just looking for if its ok to apply to fiberglass that is below the waterline... will it seal it out? Is it truly waterproof?
Yacht Dr.
Is it good enough to patch large 1"-2" chips (below waterline) in the gelcoat that are down to the fiberglass? (if it even is)
Need pics .. there is no way we can tell you application without seeing it..or some description of What happened . ( did your anchor fall off and put a dozen Pock marks on the bottom ? or ?
Give us pics or at least a bone here LOL ..
If not..then yea..resin coat it and your good to go ... ;) .
YD.
Sharp Shooter
Resin without glass is brittle and not a good fix by itself.
Sharp Shooter
No, you're talking about "reinforced Bondo".
Woodonglass has the best fix...
...cut some small pieces of CSM, Grind em out a bit with a dremel tool, wipe it all down with Acetone,and patch em with mat and resin. Resin without some glass is pretty much WORTHLESS.
oops!
yea....we need pics.......each repair is different.
stay away from the bondo carp. really i dont care if the fiberglass repair manual says its ok......its not the author is wrong.
mix your own peanut butter, and your own gellpaste.
