sangalanga
Thread starter- Joined
- Apr 14, 2009
- 12
glassing the hull to deck joint
Hey guys,
We are in the process of restoring a 1983 Wellcraft Windstar 19' Sailboat. We found the hull to deck joint in ok condition however there are some spots that will not keep the water out. As you can see from the picture the joint is a flange type. Took an agle grinder and got all of the gelcoat off down to the fiberglass, caulked the bad spots and put in stainless steel screws every six inches. My question is will the fiberglass be able to bend around the flange's sharp 90 degree corners and still maintain a smooth surface? Would like to fit a simple wooden toe rail over the flange after the glassing is completed. Thanks,
First picture is the
hull and deck joint flange before taking off gel coat
Second picture is the
flange after taking off the gel coat.
Hey guys,
