ficht 115 hp evinrude. spark plugs do not line up.
jodellz
Index mark centerline does line up with the injector.
Using the correct spark plugs champion xc12pepb
even tried to reinstall old ones only 3 of the 4 would work.
All new spark plugs are 180 out. Any help would be greatly appareciated.
ok to call Randy 951 318 4896
noelm
Re: ficht 115 hp evinrude. spark plugs do not line up.
you will need to swap them around and try extra washers on them, plenty use that system and it seems to work OK.
boobie
You can try swapping them from side to side.The correct torque spec is 180 " lbs -264 " lbs. The open gap of the plug can be 90* on either side of the injector. DON"T over torque!!
DiscountMarine
Definately try swapping em around learned that about fichts in trade school. Its good to number them when you take them out.
boobie
O' yeah, you Don't use extra washers on them.
