fill/drain plug gaskets
uradillybar
I have a 1970 115 johnson 4 cyl. How do you check the lube and because of the black oil substance leaking before the prop someone told me to change the fill/drain plug gaskets. I'm new to outboards so if someone could help me that would be great.
uradillybar
Re: fill/drain plug gaskets
I would like to ask a second question also. After the motor runs for a while in idle the motor will die. It was rebuilt this year but not ran much do you think I need to adjust the carb. Thanks for everyones help!!!
ED21
Master Chief Petty Officer
You really should get a manual. Lower unit lube is a maintenance item that should be drained & refilled at least anually. While the drain plugs are out you can change gaskets. Get them from a dealer or internet. The lower unit seals may also be gone. In which case water is probably getting into the gearcase. Not good for the gears & not that hard to replace with the proper service manual to guide the way.
93bronco
Ensign
the black oil could also be burnt excess oil from the motor not running correctly.<br />mine was caused by faulty power pack, once that was replaced - no more oil stain.
