Smokin'Mo
Thread starter- Joined
- Oct 12, 2007
- 32
I was in the process of filleting the stringers to hull and ran out of milled fibres & chopped strand. The supplier was closed on Monday so I thought I'd use anything that would thicken the resin. That anything was flour. Yes the type used for baking. I thoroughly mixed 1 litre of resin with 15ml of catalyst and proceeded to mix in 1 kg of flour to thicken. Although it was not quite PB consistency, after setting a while it seemed to bind ok to the existing pb mix used in the first pass. The air temp was 15c and quite humid and also started raining. As of 10:00pm last night it still had not cured (8hrs.) but seemed to be thickening. This morning it was thicker still but not fully cured. I also noticed a sort of whitening as if the flour was expanding? If it is not cured by the time I get home from work should I scrape it all out? or will it eventually harden? or was this a dumb idea in the first place?
Another area I am concerned with is where the stringers pass over a chine. There is a pocket formed beside the stringer where the chine sits and it is approximately half the length of the stringer. When filleting around this area I used a runny resin/chopped strand mix and poured it next to the stringer in the chine pocket. Is this considered a hard spot? When it kicked it got pretty hot although the hull was warm to the touch from the outside. Should I be concerned about this?
Thanks for any advise.
