Filling oil from vent/level hole on the lowe rgear case
surveyor1951
Some people told me they fill the lube oil from the top level/vent hole. I do it from below with a pump, but what would the end result if you went the easy way & filled the lube oil from the top. Just wanted to know what the conquences would be. Thanks
ziggy
Re: Filling oil from vent/level hole on the lowe rgear case
i suppose it depends on the drive mfg. specify yours if ya want an exact answer about your drive. for your typical mercruiser alpha 1 drive.
lack of lub due to air being trapped inside the drive instead of gear lub. trashed gears or brgs. drive destruction.
what's not easy about filling from the bottom drain plug? messy, but not hard.
Some people
hard to say about some people. ;)
Don S
There has NEVER been a Mercruiser outdrive that filled from the top. Always from the bottom.
Put them on a list of people to never listen to when doing your boat repair. Might want to watch their boats though, they probably don't last long.
JimS123
Filling from the bottom IS the easy way. Doing it from the top takes almost forever, waiting for it to burp all the bubbles out.
Bt Doctur
This happens
surveyor1951
My boat is a Reinell with a Mercury Alpha 1 3.0L engine & Alpha 1 drive. I will continue filling the gear case from the bottom. So much for all those expert marine mechanic friends I have, they nearly had me convinced. Thanks for all the valuable info.
