filter question/location
nightvision
A question from a newbie here. I have a 2005 180 sport, with a Mercruiser 3.0L and an Alpha 1.
a. Please tell me where the water separating fuel filter and the boost pump pre-filter are located. The maintenance chart indicate that it should be replaced every 100 hours or annually. Are these do it yourself items?
Thanks.
Re: filter question/location
It Probably doesn't Have a spin-on W/S Filter....... Most small boats with 3.0l motors didn't have it fitted from the factory....
The Only Fuel Filters on those motors are the 1 Inside the Fuel Pump,+ the 1 Inside the Carb. Inlet Fitting......
Adding a Spin-on is Always a Good Idea...........
