Neverquit
Thread starter- Joined
- Nov 28, 2018
- 51
Took the Starcraft out again today, fishing was slow but we still brought a few home.
Engine was running good and I was expecting to see better performance with the fresh carb, better but still not there.
Was hitting 3500 RPM and 37 MPH on the gps today.
I tried taking off the 14 x 19 prop and put on the 13 x 17 expecting to see higher RPM, No seemed it was only getting just over 3000 RPM and top speed was under 30 MPH so I put the 14 x 19 back on.
It seems to be leveling off fairly good on plane and really it is already going faster than I need but I am still puzzled as to why I am not getting into the mid 4000 RPM range.
It does seem to act a little tail heavy out of the hole.
Weight wise in the back roughly was a trolling motor (25 lbs), 2 batteries (142 lbs), tool box (15 lbs), anchor (20 lbs), tackle box (25 lbs), daughter (100 lbs) so say 327 lbs.
Up front my wife and I, 1 battery, cooler and misc spare parts in storage area for an estimated total of 410 lbs plus a full tank of fuel.
Does this sound reasonable or would shifting some weight around help?
Can anybody with roughly the same boat motor and prop combination share what RPM's and MPH you are getting?
85 Starcraft holiday 18 with OMC 140 engine and 14 x 19 prop.
Trolling it was running smooth as glass pushing along at 3.8 MPH @ 650 RPM.
