finally got spark, but won't start
bkyser
History,<br /><br />You helped me figure out that I needed a new switchbox, and internal wire harness for my boat. 1969 80HP Merc. 800 Thunderbolt ign. Ser# 288147.<br /><br />Thanks to you, I now have a good strong spark. License was expired, so I couldn't put it in the water to run it, and didn't own (ear) muffs.<br /><br />I went to the lake the next weekend to test run it, muffs in hand, new boat license, full tank of new gas.<br /> <br />I squeezed the bulb, and felt it go soft....... broken fuel line. Replaced all the hoses ( just in case) that I had to get custom made at a local company ( cost way too much, but still less than ordering from Mercury)<br /><br />Went up last night, changed the fuel filters ( since the lines were off, and they were really easy to get to, I figured it would be a good time. Old ones looked as good as new, but changed them and the gaskets anyway.<br /><br />Finally, squeezed the ball, good pressure. Turned it over......... would not start. Gave it a shot of starting fluid ( I know its not a good thing, I was just testing to see if it was that the carbs needed rebuilt.) Turned it over again, and it didn't sputter until I stopped turning it over, every time I let go of the key, I would get one backfire out of the exhaust.<br /><br />Is there a chance that the timing got changed that much, just by changing the switchbox? I still have a good spark, and it sure smells like its getting gas....... sniffing the cylinders and plugs.<br /><br />Any ideas before I get a shotgun, and put several big holes in the side of my ( getting very expensive now) motor?<br /><br />Got home late last night, wife asked if it worked, I told her no.......she rolled over and said...." I told you to sell it"<br /><br />Any ideas would be helpful. If I don't get it fixed pretty soon, I'll have to go back to my little rowboat for fishing.<br /><br />Thanks<br />Bob
NathanY
Re: finally got spark, but won't start
When ever you replace a switchbox on any Merc, it needs to be re timed.
bkyser
Don't shoot me for this, but do you have any idea if it sounds like the spark needs to be advanced, or retarded? I don't own a timing light.... don't even know who might. Is it possible to get it close, just by ear?<br /><br />Thanks<br />Bob
suzuki40
You need to do it right. go have it timed and be through with it,you and your wife will sleep better at night instead of putting a lot of worry into this thing.<br /><br />Suzuki40
LanceM
I think that is MY wife he's talking about!
NathanY
No you cant do it by ear. An inline merc will burn up if it is more than 3 degrees out. Timing has to be set at idle and at WOT. My local mechanic charge me 30 bucks to do it. If you do it yourself, you will need a timing light and a dial indicator.
mellowyellow
careful Tex.... LOL<br />got 2 pals who is troopers in TX. :p
bkyser
I'm convinced, I'll have marina do it right now if wifey-poo will loosen the purse strings just a little more.....<br /><br />Thanks
