scout-j-m
Thread starter- Joined
- Jul 31, 2009
- 643
I was able to take it for another spin yesterday evening. I verified that the carb butterfly was perfectly horizontal. I also set the timing dynamically to exactly 30 degrees. I tried all of the my tests mentioned above: totally disconnected the rectifier/regulator, disconnected the tiny tach from the plug wire, and swapped the black/yellow leads on the switchbox to the wiring harness kill switch wire. None of those made any difference in performance except I think the timing may gave given me a slight boost in rpms. I also tried pumping the primer ball (was still hard) and also squirting a little carb cleaner in the throat at WOT to make sure there wasn't any kind of fuel delivery problem, which there wasn't.
Performance-wise, this time I was able to hit 36mph and 4500 rpms at WOT. The boat seemed to get up and ride on plane better than the first trip, even at lower rpms. It still idle pretty well and ran nice and smooth at high rpms's. It does seem to occasionally have a miss or two while accelerating hard but I still haven't fine tuned the low speed idle mixture screw like I need to. I guess at this point I will try to get through the break-in and see if my wot rpms go up over that time before considering a re-prop.
BTW, anyone know the LU gear ratio of my motor? I'd like to know to use it in some prop calculations. I seem to remember it was somewhere around 1.7 to 1.8:1.
