Finding what 4.3 GXI I have also cleaning of almost new AC iridium spark plugs
Status
Not open for further replies.
al1026
I have a 2003 Regal Commodore 28.60 model
Twin 2003 Volvo Penta 4.3 GXI engines ( red vortec )
Duo props on each lower unit
On top of each engine it has a plate that indicates timing, idle rpm , ignition timing , covers multiple GXI engines ,
4.3 GXI 5.0 GXI 5.7 GI 5.7 GXI
April purchase a learning process.
How can I find my exact GXI engines,
Don't see it on engines, if so were ?? hull number help ?
Cant order any parts saying 2003 Volvo Penta - RED 4.3 GXI . they say which GXI there are many ???
What shop manual would you recommend ?
ALSO
Possibly beaten this topic too death but is there a way too clean almost new iridium spark plugs
Let me explain
After purchase I had a local shop do some work.
Besides the work I brought it in for , they said I needed new plugs .
Engines had iridium plugs and they replaced with new AC iridium .
I try to do most of my own repairs when possible , but find with twin engines no room too get around
Recently developed a power steering leak.
Actuator had too be changed.
On this Regal actuator is behind starboard engine very difficult too get too .
I live inland, keep boat at ocean 11/2 hrs away
Brought boat into a shop I never used close too the marina were boat is kept
While there shop said I needed basic service , had slight water pump leak starboard ( which I knew )
He pulled one of the plugs and said it was dirty with carbon ?? Saying they were changed few months ago with little hours .
Need too address why they have carbon built ( if this guy telling the truth ) ?
Actuator is completed. Thanksgiving & Christmas this shop was closed often.
Nothing was done on engines. Christmas just passed, decided too pull boat and do all other work myself
The cost of 20 dollars a plug iridium verses 5 dollars for a good old fashioned AC or NGB you can clean with sand paper .
Cant use sandpaper or wire brush , how about torch burning off carbon. cant imagine a lot of carbon , what solution if any ?
If I get new standard plugs what numbers remember I have a Red 4.3 GXI engine
thanks for what ever help you can offer .
Fun Times
This may help with where to find your full engine model,
http://www.volvopentastore.com/mall/template/store/volvopenta/help.html
Cleaning spark plugs isn't really recommended by some as it could degrade the performance of the plug but for testing purposes, it shouldn't be much of a problem if the plug are truly fouled.
http://youronlinemechanic.com/platinumiridium-tipped-plug/
http://www.bing.com/search?q=how to...=-1&sk=&cvid=3BCC71BD2F034B0FAF5EBF1209DA11E0
You may find that Volvo recommends Champion spark plugs as a new service plug after your original AC-Delco plugs are in need of replacement. Champion plugs are typically frowned upon here on iboats forums as many (not all) have found them to be the most defective/unreliable plug made....Your mileage may very though.
If you search the spark plug numbers either online or call around to your local auto stores, you can find the iridium plugs at a much lower cost than a marine dealer has to sell them for.
monster1
I have a 2004 4.3gxi-e. The plugs I just ordered for it are AC Delco 41-101. Got them off eBay for 5 bucks each.
donald maclaren
Hi, I hope you guys are still around. monster1 I have a 4.3 GXI-G and replacing my pluggs that were 41-993 with 41-101(next model). My Penta book says to gap .06, the ones I pulled were like .05. I couldnt' get the engine to start with them at .06 I put them in at .045 and I got good crank but have not had the boat in the water yet.
What gap did you end up using?
GA_Boater
Start your own thread if you want an answer. We have a few V-P guys around all the time, unlike Monster.
Closed.
Status
