Finding where a Boat leaks
southkogs
Re: Finding where a Boat leaks
Got any pictures? Sumtin' doesn't sound right.
oops!
It is a fiberglass and I have two live wells but I never see any water in them I have all so changed all the plugs but I will take a look at the plug holes (ware the plug goes into) it has thru hull fittings under the boat.
Thank you for all the help.The boat is on a lift so that is how it goes into the water
Rick
thank you.
there are only a few reasons for leaks in a fiberglass boat.
1. thru hull penetration.
2. thru hull fitting/hoses leaking
3. drain plug fitting/incorrect installation
4. intrusion under the cap hull joint. (under the rub rail)
5. incorrectly sealed motor bolts/ transom mounted accessories
6. drive bellows/ drive seal/ shift shaft boot.
1. hull penetrations of a fiberglass boat are easy to spot.
look at the bottom of hull..... if there is any areas that the gellcoat is chipped away so the fibers are loose.......this is a suspect area (but rarely a penetration)
if the area is still suspect after careful examination.....marine tex is a cheap quick fix that will allow you to continue the search with out much time spent on a repair that may not be the real problem.
2.......take a look at the tru hull fittings of the live wells...... not just the fitting....but of the hoses that are connected to these. hose clamps hold on the hose, and can split the hose. a incorrectly working live well can pump water into the boat very fast.
3. the most simple check......look at the bilge drain when the boat is in the water....
4. rub rail intrusion. this will only happen when the boat is getting waves up under the rub rail. so if the boat is sitting on flat calm water, and is still leaking....you can rule this one out
5. look at any bolts that go thru the hull.....swim ladders....trolling motor mounts and the bolts that hold your motor on.
6. this is for i/o setups only....it is not applicable in your situation.
check all these.....and you will find your leak.
but im leaning toward the live wells
Solittle
If you can't find where it is leaking in - find out where it is leaking out. Put it on a trailer - get it dry then get you a hose and start putting water in. Where it leaks out is your problem.
oops!
tough thing to do with a glass boat. if this is a foam problem (which i do not beleive it is in this case could add to the problem).......but adding food color to the water.....is a good idea if you go this route.
rte592
When I'm checking out a new to me boat for leaks I leave the boat tied to the trailer.
I jump in the boat armed with a bright flashlight and have someone back the boat into the water to check for leaks.
the extra weight of the trailer helps as the boat gets pulled down.
Slow Ride
I had a similar experience years ago and found that the livewell pump was leaking into the hull. Since it sits lower that the water line (in most cases) it normally fills with water as soon as it leaves the trailer. It was difficult to find because all the hoses were in good shape and it was not until I removed the pump and inspected it that I notice the big crack in the housing. It's rare but worth a look in my opinion.
rickj1
Thank every one again for the input. I will start the repairs today sometime and let you know the outcome.
Again thank all of you for the input..
Rick
oops!
rick.....if you see something that looks weird......or you just dont know why its there......just take pics of the area and post them.
the iboats crew will help you find the reason for this......but take that check list i gave you.....the answer will be in there some where.
