rolmops
- Joined
- Feb 24, 2002
- 5,745
I have a 19 foot Islander (1984) with a 4 cylinder 3 liter engine with good compression across the board and the points replaced by electronic ignition. When I troll at roughly between 750 and 950 rpm everything goes fine for the first hour or two , but after that, the engine starts running rougher and sometimes it just quits on me. Than I have to restart it in neutral and when it starts it leaves a bunch of brownish to black carbon floating on the water. Than it will run again for another hour or so. When I pack up to go back to port the engine has a hard time to pick up rpm and sometimes just stalls. I have to very gradually increase rpm and after a few minutes it runs just fine. Why is there carbon buildup? I replaced all my fuel so it is 91 octane ethanol free and fresh. The spark plugs are ACDelco43LTS. My carburetor was professionally rebuilt. Is my timing a bit off? What else should I look for so she runs smoothly at low rpms without carbon buildup?
Thank you for any advice and help, Cornelis
