Finnish fishing boat overhaul [Splashed 2017]
Teamster
I'd maybe think about the sound deadening material used in hot rods,.....
I think it also insulates some, and it should help block out unwanted sounds if your sleeping on board,...
Red Herring
I'll have to look into those, might be hugely expensive in Finland though. Maybe I can find some local alternatives.
Red Herring
Back to work this week, the other work was getting inbetween. I'm joining the Hate Grinding club. There's been a lot of it lately. Tomorrow I'll finally start with the other stuff. Will post pics when something substantial can be seen.
Red Herring
Deck rebuild on the way. A local boatbuilder told me I could leave the aluminium sheet on the polyurethane since it's just used for giving form to the glass. What do you guys think? It probably won't stick, but then again it really doesn't have to? Anyone tried this?
Red Herring
Mixed thickened resin or peanut butter for the first time today. Tried out different mixes and noticed that my catalyst kicks in a bit slow. Might be the temperature +17c of course, but at least it works. Fixed a lot of holes and sanded the boat lip (top, or what is it called again?) nice and smooth. Feels great to finally have started doing something with visible results.
seanymphmike
I think you're referring to the gunwale (pronounced gunnel) but I've noticed you speak English better than most Americans😊. That is going to be one beautiful boat. My compliments. You certainly don't take any shortcuts. I've been lurking following your progress. Amazing work! Thanks for sharing.
Red Herring
Thanks guys! Some days I get overwhelmed with everything that needs to be done, looking at the project and just seeing a money sink wreck. It helps a lot to read through this thread in those times of despair, realizing how much has been done and all the positive comments quickly turn the mood. My social life has taken a turn for the worse though, hopefully it will be mitigated after the boat is done and I can take friends and family out and about. Our language skills in this backwater country have to be good for us to survive, five million people speaking Finnish makes it a pretty marginal language :)
seanymphmike
I suppose it's easy to get overwhelmed on a project that is the size of yours. Your approach is logical though and you seem to be eating the apple one bite at a time. You have a mighty big apple but you will get it all eaten and when you're done I can only imagine how satisfied you'll be. But you're Finnish! When your mood gets down, crank up Sibelius on the stereo! That always makes me feel better:)
Corjen1
WOW, great project and great progress!!! Mind if I tag along and see your dream come true?
Teamster
I look forward to the updates on this,..
And the video of it underway when it's done,...
Red Herring
Back in town earning more money to spend. Did a quick photoshop sketch with the rails and hull colors approximately correct, feeling quite confident about that part for now.
I'm getting a big diesel heater for the tarp tent and hoping to finish most of the glassing in september. Not sure how well the tent keeps warm after the heater is turned off though. Hopefully long enough for the resin to kick.
Thanks again everyone, will post more stuff in a week or so!
nurseman
Looks great Red Herring! That cabin looks really good on her, and the colors look good too.
Red Herring
First tryouts with waxed gelcoat today. It looks ok in the photo, but it will need some serious sanding before it's really good. I'll try finishing rest of the gunwale(thanks seanymphmike!) tomorrow. I'm kind of in a rush to get all the structural glassing done before it gets too cold, I'm afraid most of my chemicals will be too old next spring. So the sanding will be left until later.
jigngrub
Well Red, I gotta say you're doing some beautiful work there on that boat and it should last into the next millennium. Always a pleasure to see a craftsman at work.
Red Herring
Thank you sir! Got the gunwale covered in three/four layers of topcoat now. I did the last layer with a trowel as per a local pros suggestion. I get the idea, but I have to admit that the rolled on surface would probably have needed at lot less sanding. Ah well, maybe I'll avoid sand throughs this way when it eventually is time for finish work. Actually, the rolled surface looked real good, it will give a perfect finish to the interiors of the boat not going through a mold-job.
I removed the aluminium backing from the poly sheets, some people seem to use aluminium foil as a mold release, so it felt more secure this way. Then again, I spent most of the day sanding and messing around with the sheets because of that. Still need to add some fillets and sand a bit before layup time. Maybe even tomorrow if all goes well. Had to learn how to use a router at the same time, it's a great tool and really fast to use. Just made me hope I would've used it before the sheets were in place like they were now.
I had some problems with my peanut butter, I think I'm mixing it too hairy. Checked out Friscoboaters PB tutorial on youtube and it seems like he uses at least twice the amount of silica than what I did earlier. Will remedy that tomorrow and hope for some smoother fillets and more importantly, less sanding.
Rickmerrill
Wood's PB recipe is 1L resin, 1.5L Cabosil and 60ml of 1/4" chopped strand. Using a thick plastic bag with a corner cut out (think bakers cake decorating bag) to squeeze out a consistent bead really helps. Then go over with your spoon dipped in acetone and smooth the edges with a plastic bondo spreader.
nurseman
I had the same problem with my PB at first. I was using way too much chopped fibers, made it almost impossible to work with. If you follow Woods recipe, and the technique that Rickmerrill outlined ^^^, you will be amazed at how nice it turns out! Good luck!
