Firefox
NYBo
With the latest update to Firefox (60.0b4, 32-bit), the site is jumbled up. Anyone else having this problem. No problem with Chrome.
NYBo
[No message]
GA_Boater
60.0b4 is a beta or test version, The current stable version is
Click image for larger version  Name:	quantum.PNG Views:	1 Size:	41.1 KB ID:	10547645
Just updated yesterday and it works fine.
You found a bug in a test version which can be expected. Try using the 59.0.1 version, it's been functioning normally.
NYBo
I imagine that's the version (59) I had until the automatic update hit. Going back may prove...interesting.
NYBo
Well, that was surprisingly easy! I don't know how I ended up with a beta version, but no more automatic updates for me.
Thanks for the heads-up, GA.
GA_Boater
Check your Firefox settings. Make sure that "release" is the Update Channel. The 1st and 3rd options below work to find the setting. The 2nd option is too indirect. The paragraph about the installer applies for the latest version, not just 56.0.1. The write up is from a a few releases ago, the rest is still current. Oh, this is screen snip so the links aren't links, just a picture.
This is what you get after using the 1st or 2nd method;
NYBo
Reverting to the stable version apparently put me on the "release" channel. Thanks again.
