twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
Just picked up an early 50's 7.5 Firestone. It had no ignition. I 'dressed' the points ( and gapped them) and it started right up, ran nicely, and pumped well. However, it would not go to high rpms or idle. I found the lower cylinder was not firing even though I hooked up an in-line spark light and had great spark according to the light and manually by the exposed plug. I though maybe the coil was shorting. I replaced it with an OMC coil on the Firestone field and the same thing. Spark at the plug and by the indicator light but the cylinder is not firing. I then replaced the condenser with an OMC and once again had great spark at the plug and according to the indicator. The cylinder is not firing. By the way, I know the cylinder is not firing since I can pull the spark plug wire while running and there is no difference in it running and the cylinder is cool. The only thing I haven't replaced so far is the plug wire but why would I have spark at the plug but the cylinder is not firing at all? This is one I can't figure and hope someone has some ideas. I've never seen anything like it. Help!
