Firing on 1 cyl. What else could it be???
deedaad
1980 2 cyl. merc 40 hp. changed out the trigger, stator, rectifier, switchbox, coils. It has 145 lbs. of compression on both cyl. but it still has no spark from the switchbox to coil #2 Is there anything else that would prohibit spark?
Kalvyn
Re: Firing on 1 cyl. What else could it be???
have you checked your distributor?
deedaad
Turned out that the coil was bad and the mercury switch was also bad.
