Firing Order
cryoman
I need to find firing order for aq125 b volvo penta :confused:
Haut Medoc
Re: Firing Order
Not a Volvo man, but if it is a GM 4 cyl. it should be 1-3-4-2.....JK
cryoman
Re: Firing Order
Okay I just found out also 1 3 4 2 Looking at distributor how do you tell nothing was disconnected from distributor , My son just pulled them from spark plug , And also 1 is closest to flywheel right :rolleyes:
cryoman
Re: Firing Order
Sorry about the bad post more correct info , On the dist how do you tell which is 1 2 3 4 are they marked Thanks
Haut Medoc
Re: Firing Order
1 is front of engine, is it not marked on the cap?<br />1-3-4-2 in a clocwise direction......JK
cryoman
Re: Firing Order
Thanks for your help , I will look on cap , still a real novice at this , I need to make sure he marks wires next time
