eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
So, after taking my boat to the lake a couple of weeks ago and noticing an inordinate amount of noise coming from the trailer (but the hubs did not get hot, so I assume I was on the path to breakdown, but not there yet), I decided to undertake my first ever hub servicing on my trailer (single-axle, no brakes, probably light duty trailer. My boat weighs less than 1000 Lbs and is 15' long). I went to Northern Tools to get all my supplies remembering when I had been there that they had extensive trailer maintenance stuff. I figured that for the cost, I might as well just replace the bearings, seals, etc. The kit I bought from Northern had everything I needed, but the seal was ABS plastic instead of metal around the outer surface. This worried me since what I removed from the hub was a metal disk, but I figured I'd ask the experts here. Will the plastic seal be sufficient, or should I go on the hunt for metal seals? Any opinions or suggestions would be greatly appreciated.
By the way, the bearings were shot. Water came out of the hub when I opened it up, and the inside bearings were about falling apart. I got real lucky that didn't happen while I was on a longer trip!!
Rgds
Rgds
