First Restoration project ( Gonzo )
mudmagnet63
turfman
Re: First Restoration project ( Gonzo )
Is the name of the boat "white knuckles"..
I use the blue gel stripper from HD or lowes; doesnt seem to make the fiberglass soft. I think its about 20 a gallon.
turfman
mudmagnet63
I was going to go with Gonzo but I kinda like that. might have to rethink the name:confused:
60 grit sandpaper
This is a forum for boats not rockets.I tried paint remover but it took off more than I wanted.Used random sander with automotive sandpaper.Alot of work.
mudmagnet63
I'm a little concerned about using to many chemicals to remove the paint. what i've tried so far was just in a couple spots. I just bought a DA sandrer and a 12" block sander. I just keep thinking there has got to be a better way. I have redone cars and there's just so much chemicals can do.
Maybe sand blastin will work. Takes time but it removes what ever you want it to and it doesnt affect the under body.
mudmagnet63
I really need some advice on how to start removing the deck. what should I look for while taking it out I'm a novice at this, I have restored cars but this is diffrent. How is the best way to start removing the deck? some advice would be much apreciated.
turfman
Well if you have a decent air compressor and a cutoff grinder, should take you about a half hour. You can use the metal blades which probably makes the job less dusty; but all I had was the composite ones. Tyveck and respirators are a must for this type of destruction. I just followed the contour of the deck but left a lip about an inch of the walls for making a template at a later time.
turfman
