JohnsonBargeMan
Thread starter- Joined
- Mar 31, 2013
- 26
I recently bought a 1996 40hp Mariner Force oil injected 2 stroke outboard. It had been sitting for about 4 years.
To skip the long story, scroll down to ***********
I think I may have already done some injustice to it by attempting to start it without first doing some initial work on it, so I don't want to take the next step of running it before confirming some other things (ya, I know, the horses are already out of the barn! but hopefully no damage done))
Anyhow, like I said I tried starting it. I first cleaned the gas tank, put fresh gas in and pushed the new gas through the gas lines to the point where it enters the engine. Tried multiple times to start but no go. Plugs appeared dry. So in an attempt to see if there was some other issue rather than gas, I squirted a bit of gas into each cylinder and attempted to start again. This time it fired (I only let it fire for about 2 seconds). So I figured the gas was being blocked someplace between the gas connector and the cylinders. Turned out that the gas pump, carbs and bowls were full engine oil. Not sure if that was on purpose or if somehow oil syphoned over the years from the oil tank. I took apart the pump and carbs and cleaned them out good.
Attempted to restart again and almost instantly if fired up. Happy days! Again, only fired it up for about 3 seconds. Stopped working on it for the night which gave me time to think.
So for a long story, my question is this. The gas lines, fuel filter and carb bowls are all full with straight gas (or I assume they are since I used the gas line bulb to push the gas through to the carbs). Is it ok to run this gas through until the mixed gas gets into the system? I assume it would be common for this to happen.
Also, how do I know the oil injection pump is working? (or should I say, is there an EASY way to know if the injection pump is working?)
Oh ya, I intend to replace the impeller before taking it out.
