First start up of 2 year rebuild. Back fires from intake manifold !!!
spybot
flutter, maybe, unless the lapping is dead on perfect, along with the reeds
Well i can assure you that the lapping WAS dead on perfect. I got a sheet of 6mm 1/4" glass.
Glued and Tapped some 1200 grit wet & dry then polished them till no high spots remained. So in my opinion yes the lapping is dead on perfect.
Regarding whether this is a good or bad thing, it depends on where you read. I think if i can make everything as free flowing as possible it can only be a good thing.
Faztbullet
I polished the the barrels after the butterfly (Made sure the Idle circuit was ultra clean.)​
This could be a problem as you may have altered the signal in/to for the idle circuit...make sure sync/link between carbs is correct. If it still spit goe to a .032 jet
spybot
Will do a proper Link/sync
Regarding the jet sizes i will have to look at what is in them just now. I went with Racers recommendation of starting 1 size up from standard again i will have to check which jets i used. Looking forward to the reeds arriving and get it started. I will try and take pics/videos of each thing as it happens.
She should be a quick wee motor once its broken in.
My idea was to put her on the back of a 16ft speedboat. A similar hull to a ss sidewinder. But now i have had a re-evaluation of the parts/engines i have gathered over the last 3 years or so, there is enough to build another 140 to the same spec.
So my new idea was to build a pod on the back of a Glastron 2000 and hang the 2 140s of the back.
Crazy idea i suppose but heyho keeps me out of trouble. The thing i struggle getting hold of here is wiseco pistons.
RaisedByWolves
Regardless of what you read, physics is always right.
https://www.youtube.com/watch?v=1q78H0BdDro
By lapping out all imperfections you gain nothing as far as sealing goes and you introduce issues with surface tension making the reeds stick and not operate properly.
spybot
So by lapping out all imperfections you reckon this is worse than leaving an uneven surface which will not close 100% ????
The surface tension in the example above covers 100% of the rulers surface. The reeds contact the cage with less than 10% of the entire surface maybe even less.
I think you are wrong.
I am sure someone with more knowledge on reeds than i have will chime in and put us right on this matter
spybot
Some words on the subject of reeds and cages, straight from the horses mouth and i quote
" OK,some thoughts and observations regarding reed sealing,leaking, cage lapping,cage surface,material,and wet and dry reeds.
First, realize that the Reeds open and close very fast, faster than you might think. A motor running at 4500 RPM is turning over 75 times a second, its reeds are opening and closing in half that time, because they remain closed on the down stroke of the motor, opening and closing at the beginning and the end of the upstroke. So, from their point of view they are opening and closing 150 times a second. They don't have much time to leak, and what we usually perceive as leakage, the mist coming from the carburetors, is not leakage at all , but reflux.Reflux is the fuel/air mix that escapes the crankcase at the end of the intake stroke as the crankcase begins to pressurize, before the reeds close.Lots of factors govern how much reflux takes place, the main factors are the weight and stiffness of the reeds the themselves,heavier metal reeds suffer more reflux than lighter composite ones,Our glass reeds usually weigh about 1/2 of their metal originals,helping them to open and close quicker...more in/less out.
As for lapping the cages, I recommend it. Usually a sheet of 400 paper, a little soapy water,a very flat surface a few minutes is all that's needed. Preparing the cage surface is important not so much for the sealing aspect but to provide a flat surface for the reeds to land on without damage. Realize the average reed leaf is probably around 1/3 of a square inch, case pressure is around 6 in.², resulting in about 2 pounds of force pushing each leaf shut at a cyclic rate of 2 to 300 times a second on a high-performance motor...not much time to leak…but even tiny flaws in the cage surface will quickly damage the perimeter of the reed leafs,that support that 2 pounds of pounding force.
Realize also these reed petals are very close to the spinning crankshaft , and do not always land flat on the face of the cages.If the surface of the cage is not smooth and hard the reed corners will dig into the rubber and ruin the surface,break the reed or both.This has become a major problem for Mercury motor built from 1996 on.
Wet and dry reeds, not much difference. Even dry reeds are lubricated by the oil from the crankcase that escapes back into the intake tract during reflux.
Chris,CCMS reeds "
