sundowner205
- Joined
- Jun 18, 2008
- 213
Hi guys,
So my boat was running fine...left the battery selector switch on for a few days by accident, I think it discharged the cranking battery because the starter wouldn't quite turn-over - just kinda clicked like when a car battery doesn't quite have enough juice to start it. The battery is only about 2 months old - took it home to charge it, my charger is only 1.5 amps and it took about 2 days to say it was "charged". Reconnected the battery and the only thing that worked was the auto bilge pump - no other electrical accessories worked, and it definitely wouldn't even click when i turned the key. Is it possible that my charger screwed up my battery? 2 days seems kinda long to charge even for 1.5 amps....
To make atters worse, after I disconnected the battery a few times, in all my haste, I managed to hook the battery cables up backwards - a little smoke from the battery, but surprisingly no burnt wires. All grounds and cables are tight - the boat is an '89 Four Winns Sundowner with an OMC 5.7 Cobra...I looked for blown fuses in the engine compartment - couldn't find any, I think the ones under the helm are OK....I'm hoping it's just the battery causing all the initial problems...HELP
