I have wired a lot of trailer connections, but never with electric brakes...I want to use the large 7 blade connector (universal) to put on my '07 Dodge 1-ton flat bed, the '05 P&J trailer has a 5-pin round connector. (of course I will use an adapter) The 7 blade female is factory marked-white, blue, red, brown, green, black & then the center. The 5 or 6-pin male is not marked. Of course I'm familiar with Brown, Green, yellow & white. I can use a test wire to find those on the trailer. Now I'm not sure on the brake wire...can I damage anything by powering up the wrong wire (backwards)? And, is there any 'standard' for those colors on the 7-blade connector, I see that there's no yellow...? ...is white always ground? is there a standard color for the brake wire? Also I have a used brake module without instructions, but wires are marked red-30amp, blue-trailer, black-ground and a smaller gauge light colored wire marked 'brake sensor'. Do I need a special 'sensor' to use with this module...? Any help would be greatly appreciated. Thanks.
