Tim Frank
- Joined
- Jul 29, 2008
- 5,346
Re: First time out, major shudder / vibration...
Put the old prop back on for 5 minutes...then you'll know for sure...
Back on the water this morning, 35.4 MPH without trim and correct prop. Shudder / vibration is gone. Not sure if it was some of the work I did to it or the diff prop but it is gone! It's got alot of power and sounds good! Thank you guys very much!
The only issue it had and maybe you guys know off the top of your heads...When you throttle up slowly, she will bog down and eventually die at about 1500-2000 rpm. If you bring it back to nuetral and throttle it fast, she gets up and goes. Any ideas?
Thanks again! I am a happy camper, I mean boater![]()
